[Release Note] WiFi 6 Access Point - V6.25 firmware P1 has been released!
Access Points Firmware Release Note V6.25 Patch 1
Date: October 6, 2021
Supported Platforms
NWA110AX V6.25(ABTG.1)
NWA210AX V6.25(ABTD.1)
WAX510D V6.25(ABTF.1)
WAX610D V6.25(ABTE.1)
WAX650S V6.25(ABRM.1)
WAX630S V6.25(ABZD.1)
New Feature and Enhancements
1. New WiFi 6 AX1800 dual-radio Outdoor PoE Access Point is supported. This new outdoor AP designed for small business AP, NWA55AXE, comes with right-fit feature set, simplest configuration. It is IP55 weather proof rating, supporting Zymesh and wireless bridge features make it suitable for various semi-outdoor and outdoor applications for small businesses.
2. New feature, Client diagnostic, has added to Nebula Professional Pack. This feature is designed for easy troubleshooting as it summarized important events from the AP and get gateway (NSG/USGFLEX) in chronological order.
3. Radio output power configuration UI is enhanced. User now can select from different deployment types instead of only dBm setting.
4. Fix the bug originated from chipset driver code that WiFi client with WPA2-PSK/WAP2-Enterprise/WPA3-Enterprise may lost its IP address after roamed from 2.4Ghz to 5Ghz or vice versa on the same AP.
Bug Fix
Empty column stands for the mode is unaffected.
Mode |
CLD |
MGNT |
STD |
1. [eITS: 201200956] [Symptom] Root AP disconnects the repeater when the repeater keeps using the reassociation |
V |
V |
V |
2. [eITS: 210200191] [Symptom] clients keep disconnecting from the AP |
V |
V |
V |
3. [eITS: 201200268] [Symptom] SNMP OID location value is not update after applying |
V |
V |
4. [eITS: 210200396] [Symptom] the repeater is disconnected unless the root AP reboot |
V |
V |
V |
5. [eITS: 210200683] [Symptom] the station mac will show on the AP’s port as well but not only NXC port when using the tunnel mode |
V |
6. [eITS: 210100969] [Symptom] The AP is managed by NXC, and it was crash during collecting diagnostic.warning |
V |
7. [eITS: 210300399] [Symptom] When run commands in CLI User Mode systematically crash AP - show reference object-group aaa - show reference object-group aaa ldap |
V |
8. [eITS: 210300295] [Symptom] AP sent second stop message to the accounting server immediately when the station roamed from 5G to 2.4G |
V |
V |
V |
9. [eITS: 210300794] [Symptom] DCS does not work if configure as interval |
V |
V |
V |
10. [eITS: 210301207] [Symptom] The AP only transmits 5G radio due to less of wds_profile site_gen |
V |
V |
V |
11. [eITS: 210201226, 210201244, 210300970] [Symptom] wireless connection disconnected very frequency |
V |
V |
V |
12. [eITS: 210400270] [Symptom] NXC can’t apply configurations to AP |
V |
13. [eITS: 210401047] [Symptom] the station can connect to AP but failed to get IP address |
V |
V |
V |
14. [eITS: 210400252] [Symptom] 2.4GHz channel width becomes 20MHz after reboot |
V |
V |
V |
15. [eITS: 210401146] [Symptom] After AP upgrade to 6.20, the SNMP daemon is not enabled |
V |
V |
16. [eITS: 210500638] [Symptom] Can't login in nebula cloud in guest network |
V |
17. [eITS: 210501038] [Symptom] Rate limit upload not work with NAT |
V |
18. [eITS: 210301310] [Symptom] Channel width does not work as set |
V |
V |
V |
19. [eITS: 210601193] [Symptom] AP will show as repeater even if connected to Ethernet because AP can’t query 5GHz interface |
V |
20. [eITS: 210601357] [Symptom] Group Key Handshake Time out fail |
V |
V |
21. [eITS: 210700234] [Symptom] SSID not broadcast if change country to Korea |
V |
V |
V |
22. [eITS: 210701484] [Symptom] SNMP daemon not up due to configuration file sequence wrong |
V |
V |
23. [eITS: 210800145] [Symptom] when gateway is behind a NAT router, the RAP functions can’t work well |
V |
24. [eITS: 210900429] [Symptom] Socket leak after station authenticates |
V |
V |
V |
Known Issue
Mode |
CLD |
MGNT |
STD |
1. [eITS: 210400642] [Symptom] Mesh SSID is visible |
V |
2. [eITS: 210500147] [Symptom] SSID not broadcast after changing the forwarding mode from NAT to local bridge |
V |
3. [eITS: 210900596] [Symptom] Act-session ID in access stage is different to accounting stage |
V |
V |
V |
Waiting faithfully for NWA-5123 AC and NWA-1123 AC v2!
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
