Fallback to lastgood configuration
Click apply for startup-config.conf select "Ignore errors and finish applying the configuration file" ok or upload a backup config and do the same.
backup your config0 -
Connect the console cable to the gateway, and enable collection of the console log. Then try to accept the config file. If there are errors and the gateway cannot apply the configuration, information about errors will appear in the console log.
Or you can use "apply" command via cli interface (ssh/web cli/console...etc) to apply your configuration file directly, if anything went wrong when applying, it will popup the error0
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 482 News and Release
