error number: -4008 Static host have reached the maximum number
Hey,
I have a problem configuring the ZyWALL USG 50. All the Wifi users are added to the IPMAC Binding and then by the IP addresses added to Object groups granting either only local access or also WAN. I have 102 bindings and when I trying to add another one I am receiving an error:
'CLI Number: 16
Error Number: -4008
Error Message: 'Static host have reached the maximum number.'
The interface IP is 192.168.20.20 (255:255:255:0).
DHCP pool start addresss is 192.168.20.130, pool size: 126.
What can be the problem here?
Hi @piopiopio,
The error message indicated that the IP-mac binding list reach the maximum number, so that it is unable to add new static host.
Please try to reduce the IP-Mac static binding list.
Is there a limit of static bindings per interface? I can find that information anywhere.
It is hard for me to reduce the binding list - I have all the network users added as objects so that I am able to restrict their permissions (access to WAN, file server, SharePoint ...).
In order to do that I have to add every client (MAC) to the binding list to get a static IP.
Or maybe there is some other way to do that?
Hi @piopiopio,
It’s total amount, not per interface, if your static binding list amount reach this model limitation, I would suggest to use USG-110(it can up to 256).
Thank you for your help.
As far as I know there is no mac filter on USG-50. Is there any other way to group clients or deny/allow access to clients based on their mac address? It will be more than 100 clients so IP/MAC binding won't do the job.0 -
- 603 USG FLEX H Series
- 481 News and Release
