XGS4600-32F Default Configuration file?
Godbrandont
Hi, I'm trying to reset a switch back to it's factory default settings via the console port, however it says I need to upload the factory default configuration file, but I don't know where I would get this config file from? Sorry if it's a stupid question, but if anyone could help me out that would be very much appreciated. Thanks in advance.
If you want to reset via Console. You can use the CLI "erase running-config" to reset.
Go to https://www.zyxel.com/support/download_landing.shtml
Download the XGS4600-32F CLI reference guide. In page 301,
Hi @Godbrandont,
Welcome to Zyxel Community!
As @zyman2008 mentions that please implement "erase running-config" in console mode to factory switch configuration to default, and type "show running-config" to check if running-configuration is set to default configuration.
Adam
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
