Fallback to lastgood configuration
In my unit Zyxel USG310 (Firmware Version:V4.65(AAPJ.1)) always load "lastgood configuration" when reboot it, and can not load the startup-config.conf  file. How fix it, whe th unit rebot it load the startup-config.conf
    PeterUK Posts: 3,770  Guru Member
    edited October 2021
    Click apply for startup-config.conf select "Ignore errors and finish applying the configuration file" ok or upload a backup config and do the same.
    backup your config
  • jonatan
    jonatan Posts: 198  Master Member
    Connect the console cable to the gateway, and enable collection of the console log. Then try to accept the config file. If there are errors and the gateway cannot apply the configuration, information about errors will appear in the console log.
  • Blabababa
    Blabababa Posts: 151  Master Member
    Or you can use "apply" command via cli interface (ssh/web cli/console...etc) to apply your configuration file directly, if anything went wrong when applying, it will popup the error
