Fallback to lastgood configuration
Click apply for startup-config.conf select "Ignore errors and finish applying the configuration file" ok or upload a backup config and do the same.
backup your config0 -
Connect the console cable to the gateway, and enable collection of the console log. Then try to accept the config file. If there are errors and the gateway cannot apply the configuration, information about errors will appear in the console log.
Or you can use "apply" command via cli interface (ssh/web cli/console...etc) to apply your configuration file directly, if anything went wrong when applying, it will popup the error0
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
