Troubles connecting AP behind firewall ...
Trouble trying to connect to NWA210AX behind a new USG Flex 200. The AP's are on the managment VLAN1, but do not get an IP through DHCP. Other devices do get one, such as switches. Trying to force an IP by the DHCP static table on MAC doesn't work either, though it seems to get the IP somehow (results using an IP scanner) I can not reach the webinterface. Pinging to this "obtained" IP results in 100% loss.
On other VLAN's it all works like a charm, all devices get IP's and are able to connect to other devices as well as the internet (if required).
When physically connecting the AP's to the LAN1 they keep blinking amber/geen. As soon as the AP's are connected right in front of the firewall they boot up and connect to the network as well as NCC.
All VLAN's are configured, it seems like I am missing something ... any thoughts?
Situation of the network:
- ISP router:
- WAN IP equals public IP
- LAN IP: 192.168.10.1
- DHCP: 192.168.10.220; pool size 25
- USG Flex:
WAN interface, DHCP enabled
WAN interface configuration:
When DHCP enabled on WAN port:
LAN1 interface configuration:
Problem solved, some redundant fiber uplinks were made recently but ... there was no aggregation/trunk set up yet and therefore a lot of broadcast storm. All problems solved as soon as the redundant uplinks were pulled out (literally).
- 237 Nebula Ideas
- 6.8K Security
- 744 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
