DNSSEC implementation. Anything needed on my USG?
Working on implementing DNSSEC support, so our mailserver, sitting behind a USG 110 can utilize e.g. DANE, in addition to increasing security around DNS.
I can't seem to find any Zyxel documentation mentioning DNSSEC for the USG series, so perhaps I don't need to do anything on that?
Currently, we don’t support DNSSEC, we will put this idea to our future development evaluation.
I don't think last time I checked DNSSEC is supported yet you can check here.
"Yes, your DNS resolver validates DNSSEC signatures"Assume that it should work for the mailserver as well then
Odd I checked here and the USG failed for DNSSEC...maybe you use a DNS by ISP or other?0
My PC uses USG for DNS, which in turn uses my ISP's DNS servers. So I assume they support it. Also our domain is DNSSEC enabled, so incoming traffic is also good to go.So right now, it seems to work both ways. Just need to get my head around DANE
@Zyxel_Jeff Thanks for your reply. It seems like my use-case doesn't require USG to support DNSSEC, but I assume other scenarios would, so it would probably be wise feature to implement.
Same trouble is here.mrwee said:Hi,Working on implementing DNSSEC support, so our mailserver, sitting behind a USG 110 can utilize e.g. DANE, in addition to increasing security around DNS.chat alternativeI can't seem to find any Zyxel documentation mentioning DNSSEC for the USG series, so perhaps I don't need to do anything on that?0 -
The same trouble is here.mrwee said:Hi,Working on implementing DNSSEC support, so our mailserver, sitting behind a USG 110 can utilize e.g. DANE, in addition to increasing security around DNS.chat alternativeI can't seem to find any Zyxel documentation mentioning DNSSEC for the USG series, so perhaps I don't need to do anything on that?0
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
