DNSSEC implementation. Anything needed on my USG?
mrwee
mrwee Posts: 40  Freshman Member
Working on implementing DNSSEC support, so our mailserver, sitting behind a USG 110 can utilize e.g. DANE, in addition to increasing security around DNS.
I can't seem to find any Zyxel documentation mentioning DNSSEC for the USG series, so perhaps I don't need to do anything on that?
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,333  Zyxel Employee
    Currently, we don’t support DNSSEC, we will put this idea to our future development evaluation.
    PeterUK Posts: 3,861  Guru Member
    I don't think last time I checked DNSSEC is supported yet you can check here.
    https://dnssec.vs.uni-due.de/
  • mrwee
    derp
    "Yes, your DNS resolver validates DNSSEC signatures"
    Assume that it should work for the mailserver as well then :smiley:
    Odd I checked here and the USG failed for DNSSEC...maybe you use a DNS by ISP or other?
  • mrwee
    My PC uses USG for DNS, which in turn uses my ISP's DNS servers. So I assume they support it. Also our domain is DNSSEC enabled, so incoming traffic is also good to go.
    So right now, it seems to work both ways. Just need to get my head around DANE :)
  • Zyxel_Jeff
  • mrwee
    @Zyxel_Jeff Thanks for your reply. It seems like my use-case doesn't require USG to support DNSSEC, but I assume other scenarios would, so it would probably be wise feature to implement.
  • dipen
    dipen Posts: 2
    mrwee said:
    Working on implementing DNSSEC support, so our mailserver, sitting behind a USG 110 can utilize e.g. DANE, in addition to increasing security around DNS.chat alternative
    Same trouble is here.
  • dipen
    dipen Posts: 2
    mrwee said:
    The same trouble is here.
