zyxel N4100 gateway - Problems with SSL certificate on welcome page (google chrome)
Hi @percoco,
It does not have effect on UAG-4100 and UAG-5100, because 1.1.1.1 is just a log out IP for authenticated user.To avoid user is unable to access log out page, you have to modify the log IP 1.1.1.1 to other IP.
Thanks @Zyxel_Cooldia.
Anyway I confirm, It work on N41000 -
@Zyxel_Cooldia
nothing above is working at my N4100 !
i can't find the "web authentication" or the "web portal general settings" were i can change the IP number 1.1.1.1
please, i need help from zyxel
Hello,I imported the ssl certificate on the N4100, and now I can show the login pageThe problem is that you can not reach the logout page http://1.1.1.1/infoThe pop up of the logout does not appearand the usual certificate error returnsI also tried with http://6.6.6.6/infoBut nothing to do0
Hello
Yes, it's not an ip address... in openSSL is in the second command.... one of the questions is:
"Common Name (e.g. server FQDN or YOUR name)"->> here, my advice is typing an local ip address like "10.0.0.1" (exemple)
Thanks @lalaland
After 2 weeks, my N4100 is running perfect (my ip address for my certifice is 10.0.0.1)0 -
Hi
I download the N4100 zip and:1. Copy Certificate.crt and private.key to local PC
2. Go to “SYSTEM TOOLS > SSL CERTIFICATE”,
Password = Pass phase
Certificate File = Certificate.crt
Private Key File = private.key
And it show
Any Help??Status: Invalid Private Key/Password 1 -
You have to create your own certificate with openssl, your own pass phrase (password - always the same) for the private.key
Common Name (e.g. server FQDN or YOUR name): put here this ip 10.0.0.1 (Exemple)
Hi
To create my own certificate with openssl, i can do it from my windows pc or i have to use a Linux pc??0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
