MAC Address Filtering Options for Managed WiFi not operating correctly
ciscorules
We have an issue regarding MAC address filtering for Wireless SSIDs on the Zyxel USG1100 .
I have configured a MAC filter list under Configuration > Object > AP Profile > SSID > MAC Filter List and added the appropriate Mac addresses and descriptions. This has been set to 'allow'.
I have then navigated to the SSID List and applied the MAC Filtering profile to the relevant SSIDs under the Mac Filtering Profile: dropdown list and pressed OK.
The MAC filtering does not seem to be working, is there any other configuration that needs to be added/ completed in order for this to work.
Anyone else come across this issue? please help!
Thanks peeps!
@ciscorules
I checked this function with official firmware 4.32 without any issue.
Here is my configuration example.
Go to MAC Filtering List, and add PC's MAC address on the deny list
Enable the created MAC filtering profile on SSID
Charlie0 -
Hi Charlie,
Thanks for the response. The steps that you have shown are exactly what I am doing. However, we are on Firmware Version 4.25. Would you happen to know if this is an issue that has been fixed in a later update?
Thanks again!
@ciscorules
We have not faced the similar situation before.
Regarding to this case,
can you update the firmware to v4.32 and also confirm the AP is on the latest firmware?Moreover, to update AP's firmwareGo to Configuration > Wireless > Firmware.The latest firmware version of AP is V5.00 Patch 5 _5.10(.5).
Charlie0 -
we have exactly same problem with USG40w
Current Version: V4.65(AALB.1)
No tested here it does work on the USG60W for MAC filtering
Do you have another AP or wireless repeater?
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
