ATP200 on F/W V5.10 - cannot view DHCP Table
RichP
RichP Posts: 6 image  Freshman Member
Zyxel Certified Network Administrator - Nebula First Comment Nebula Gratitude Third Anniversary
I just upgraded my ATP200 to Firmware Version V5.10(ABFW.0). Not using Nebula.
I can no longer view the DHCP table. Whether trying to access from the general tab or from Monitor/Network Status/DHCP Table - I get the same results - "Loading".
Is this a known bug?
  • mMontana
    mMontana Posts: 1,468 image  Guru Member
    Same firmware, same behavior on USG20-VPN and USG20W-VPN.
  • lalaland
    lalaland Posts: 91 image  Ally Member
    First Answer First Comment Friend Collector Sixth Anniversary
    edited October 2021
    @RichP, Maybe you can clear browser cache and  try it again, or access web gui with incognito mode.
