Zyxel USG Flex 500 - Tagged and Untagged VLAN on same Port or separate Ports ?
SteineggerIT
May I ask a question about how to configure a Tagged and Untagged VLAN on the same port or rather using two separate Ports.
Situation:
- Zyxel USG Flex 500
- WiFi AP (non-Zyxel) which require VLAN 1 Untagged for Management and interla Network and VLAN 20 for Guest Traffic
- Internal Wifi is using the DHCP from the Windows Server.
- Guest WiFi is using the DHCP from the USG Flex.
- Managed Switch
Since it is not possible to configure Tagged and Untagged VLANs on the same Port on a USG 500, I am not really sure which way to go to connect my WiFi AP.
Do you want to create different vlan on the same base port?
https://community.zyxel.com/en/discussion/3573/two-vlan-on-lan1
You can have one Untagged and many Tagged VLAN's on one port.
Do you have a VLAN switch? As you may need to untag a device to the tag VLAN on the USG Flex 500.
- 588 USG FLEX H Series
- 477 News and Release
