Can't establish IPsec VPN site-to-site connection
OnlineSoft
OnlineSoft Posts: 2  Freshman Member
edited April 2021 in Security
I'm currently building a VPN site-to-site. I have a USG110 to the site A, and a USG100 to the site B. I can't make a connection between these two sites with IPsec VPN. I'm also trying building the VPN site-to-site with my USG110 from the site A and my ISP professional box (which support VPN site-to-site) and I can't also establish a VPN connection.
I have checked all parameters from IKE phase 1 and phase 2 and they are both the same. I don't understand what is wrong.
From the log of my USG110 from the site A, I have this :
Can anyone help me to establish this IPsec VPN site-to-site? :)
Thanks in advance!
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,538  Zyxel Employee
    Hi @OnlineSoft,
    The error log is “no proposal chosen”, it might be caused be incorrect VPN IP connection.
    Is one of this site VPN connection via DDNS?  If yes, you can confirm if the DDNS host name and IP mapping is correct or not.
  • OnlineSoft
    edited June 2018
    Hi @Zyxel_Cooldia,
    Thanks you for your answer!
    To answer you, both site use IP address. I haven't any DDNS hostname. I have checked IP address from both site and they are the same that I use in VPN configuration :/
    EDIT: solved. My ISP professional box isn't able to establish this kind of VPN connection. I use a 4G box and it's working now.
