USG40's VPN VOIP Stopped Working
We have SecuExtender, IPSec VPN WINDOWS Client ,SecuExtender, SSL VPN MAC OS and additional SSL VPN tunnel license.
Could you share more detailed information about the license?If you have any concerns to share in the article, you can private message to us0 -
I also lost VoIP phone operation after the recent firmware update. Moving the phone outside the USG40 it works but not when it is behind the USG40.0
It is the VPN WINDOWS Client and I wonder if this is upgradeable to SecuExtender VPN Client?
Hi @ghasdorff
Could you share more detailed information about your symptom?
Could you provide your topology with IP address? Where is your SIP phone and server located?
What is the current firmware of the USG device you’re using?
Hi @ChrisBys
The license you purchased is mainly for perpetual versions and the current version is v3.8.204.61.32.
And the v5.6.80.007 is the subscription based version which requires different licenses.
Hi @StevieGCould you share your topology and the policy settings with us?What is your current firmware?
Do you mean after upgrade the firmware, the symptom occur?
What is your firmware using previously?If you have any concern to share the information in the post.You can private message the information to us.0
- 220 Nebula Ideas
- 607 USG FLEX H Series
- 299 Service & License
- 482 News and Release
