How can I get access to a AD domain using a Win10 to USG40w VPN connection?
WGLAN
WGLAN Posts: 7 image  Freshman Member
I found a description how to access a Windows AD domain from a Windows Client using SSL VPN. But I cannot buy Secuextender SSL VPN for Windows any more.
Therefore my question:
How can  I get access from my Win10 Client to a Windows AD domain taking advantage of the USG40W, which is installed today in front of the Windows Server?  For example by using L2TP / IPSEC for the VPN tunnel? Or what is the best way?
Thank you for your help!
WGLAN
  • Zyxel_Emily
    Hi @WGLAN,
    After you follow the steps in Quick Setup > Remote Access VPN Setup to complete the L2TP VPN configuration, download and install the script file on Windows 10. Dial up L2TP VPN connection on Windows 10 and it can access LAN resources of USG40W.
  • WGLAN
    Hi @Zyxel_Emily,
    thank you for your quick answer. It confirms, what I expected and what I plan to do. But I did not know about the Script files.
    Could you please add the URL, where I can find the first of your three pictures. Thanks.
    Best regards, WGLAN
  • Zyxel_Emily
    Hi @WGLAN,
    Click "Quick Setup".
