ZyWALL ATP200 two-factor authentication?
Username_is_reserved
Username_is_reserved Posts: 115  Ally Member
Hi
Is there an option to make an "offline" two-factor authentication with the ATP without Cellphone Coverage? Back then Zyxel had some token and Server Software. I never used them back then but now I want make it more secure.
Best Answers
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,537  Zyxel Employee
    Hi @Username_is_reserved,
    If you want to use offline two-factor authentication with the ATP without Cellphone Coverage. You need to write down backup code from Web GUI for 2 factor code. but it may have potential risk for security, please keep the the code in safe place.
  • Username_is_reserved
    Thanks!
  • Zyxel_Cooldia
    Thanks!
