ZyWALL ATP200 two-factor authentication?
Username_is_reserved
in Security
Hi
Is there an option to make an "offline" two-factor authentication with the ATP without Cellphone Coverage? Back then Zyxel had some token and Server Software. I never used them back then but now I want make it more secure.
Best Answers
Hi @Username_is_reserved,
If you want to use offline two-factor authentication with the ATP without Cellphone Coverage. You need to write down backup code from Web GUI for 2 factor code. but it may have potential risk for security, please keep the the code in safe place.
Thanks!
Thanks!
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
