Facebook wifi
Hi
I'm one of those how use zyxel USG firewalls and ubiquiti wireless APs together.
But im having problem using these together with Facebook Wifi at a Gym client of mine.
I want to activate Facebook Wifi at the guest Wifi not the staff wifi. But when i look thruu the settings at USG60 firewall i can only see its ether on or off not to choose what vlan or networkits activated on. and when i look in the unifi controller i cant even activate it becouse im not using Unifi gateway.
Does enyone know how to solve this?
/Joakim
Langhard,
Refer this article, https://support.zyxel.eu/hc/en-us/articles/360002868300-USG-Series-Facebook-WiFi-Login
Follow the steps. In step 1-5 to add a web authentication policy for guest interface.
- Incoming Interface: select your guest interface
- Enable "Force User Authentication"
- Authentication Type: select "facebook-wifi"
Langhard,
Tnx alot Zyman2008.
A smal question, should i remove the pass on the unifi wifi?And if. on the unifi do i choose the external portal server as an authentication typ and set the usg, in this case, guest net 192.168.6.1, as portal ip?0
Langhard,
It's depends.
If you want facebook wifi or guest portal control on unifi. Then disable web authentication on USG.
If you want facebook wifi or guest portal control on USG. Then disable facebook wifi / portal on unifi.
You can choice enable on unifi or USG for different SSID. But don't enable both for the same SSID.
And USG is not a web server you can upload web contents on it.
So that it's not possible as a external portal server for unifi.
Hello, when i enable Web Auth for redirect My Vlan10 ips to force webauth i got rejected traffic from vlan10 (ip) to any in logs , where is the problem , i can't finde it0
That's just logs of traffic blocked before the authentication pass.
From my point of view. The logs more like for debug to check if the authentication policy hit or not.
You can disable the "Web Authentication" log category in log settings.
The user login/logout logs is belong to "User" log category.
I have no answare from Web Auth... I tryed also on a VPN20 same results. I used a clean Lan 2 with Dhcp .. (no vlan at this time) enabled fb wifi paired the page enabled web auth and built the policy trom lan 2 to any force fb auth.... etc but no redirect on the captive .... i've same issue on usg110 and this one ..... where is the problem?0
- 441 Beta Program
- 209 Nebula Ideas
- 534 USG FLEX H Series
- 338 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 461 News and Release
