XGS4600-32F - SFP port issues
maxsaf
maxsaf Posts: 11
image  Freshman Member
edited August 2022 in Switch
We have an issue on some switches.  Transceivers stop transmitting or/and corrupted info from it.
Port            : 5 (SFP)
Vendor          : ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒
Part Number     : ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒
Serial Number   : ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒
Revision        : ▒▒▒▒
Date Code       : 20▒▒-▒▒-▒▒
Transceiver     : Others
Calibration     : Internal
Temperature(C)  ++       21.00        0.00        0.00        0.00        0.00
Voltage(V)      --        3.00        6.00        6.00        6.00        6.00
TX Bias(mA)     --        0.00      131.00      131.00      131.00      131.00
TX Power(dbm)   --     neg inf        8.16        8.16        8.16        8.16
RX Power(dbm)   --     neg inf        8.16        8.16        8.16        8.16
After the fiber is plugged in we can see RX but link is not established, TX still neg inf
Unplug/Plug it back everything is back to normal
Port            : 5 (SFP)
Vendor          : Optcore
Part Number     : OPB1250-5320SDCR
Serial Number   : 1815011628
Revision        : A0
Date Code       : 2018-04-12
Temperature(C)           47.00      100.00       95.00      -35.00      -40.00
Voltage(V)                3.00        3.00        3.00        2.00        2.00
TX Bias(mA)              17.00       80.00       70.00        2.00        1.00
TX Power(dbm)            -6.08       -2.00       -3.00       -9.00      -10.00
RX Power(dbm)   --     neg inf        3.00        0.00      -23.98      -26.99
After we reseat or swap transceiver link it will stay connected or drop again.
We are using different transceivers, most of them Optcore or Robofiber
  • Zyxel_Ryan
    Zyxel_Ryan Posts: 72
    First Answer First Comment Friend Collector
    image  Zyxel Employee
    edited August 2018
    Hello @maxsaf
    According to your description, your Optcore or Robofiber stop transmitting or/and corrupted info from DDMI. First of all, to clarify it it is a problem of the switch or not, I would like to know if the problem happens on all other ports or only certain ports? If it happens on all ports, I will assume that this might be an IOP problem. Due to the transceivers you are using are not ZYXEL transceivers, besides, there are too many different brands of SFP in the market, we cannot guarantee that all of them are compatible to ZYXEL switch. That is why we provide suggest SFT list in our product datasheet. We will recommend you to use either of them on our datasheet.
    Ryan
  • sahil_jha
    sahil_jha Posts: 1 image  Freshman Member
    where to check the optical sfp tx and rx power
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,093
    edited November 2021
    Hi @sahil_jha,
    Welcome to Zyxel Community!
    Below are the method to check the optical sfp tx and rx power:
    For console/SSH/telnet:
    Please type in command "show interfaces transceiver OO(the port of the transceiver, below use port 26 for example)"
    For Web GUI:
    Please go to Home page to find the port status > DDMI > port OO > DDMI detail.
    Hope it helps.
    Zyxel Melen
