L2TP over IPSEC not more working on Android 11
Hello Everybody,
Since i change my smartphone, I can't connect on the L2TP over IPSEC vpn anymore.
My smartphone config:
- Android 11
- Smartphone Oppo Find X3 Pro (ColorOS 11.2)
The VPN Config : Like this guide searchArticle!viewBlob.action (zyxel.com)
The question is : I am alone with this problem :-) ?
Thanks a lot for your help
- Android 11
Hi @virtuOS,L2TP VPN on our smartphone is able to be established to ATP200 (Firmware: 5.10(ABFW.0)).- Android 11- Xiaomi Mi A3We suggest you follow the wizard on the USG/ZyWALL/ATP/USG FLEX to configure L2TP VPN to avoid mis-configuration.0
- 439 Beta Program
- 2.8K Nebula
- 198 Nebula Ideas
- 6.3K Security
- 483 USG FLEX H Series
- 318 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 450 News and Release
- 4.3K FAQ
- 93 Security Highlight
