L2TP over IPSEC no more working on Android 11(ColorOS 11.2)
Hello Everybody,
Since i change my smartphone, I can't connect on the L2TP over IPSEC vpn anymore.
My smartphone config:
- Android 11
- Smartphone Oppo Find X3 Pro (ColorOS 11.2)
The VPN Config : Like this guide searchArticle!viewBlob.action (zyxel.com)
The question is : Am i alone with this problem :-) ?
Thanks a lot for your help
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,417  Zyxel Employee
    L2TP VPN on our smartphone is able to be established to ATP200 (Firmware: 5.10(ABFW.0)).
    - Android 11
    - Xiaomi Mi A3
    We suggest you follow the wizard on the USG/ZyWALL/ATP/USG FLEX to configure L2TP VPN.
  • mMontana
    mMontana Posts: 1,426  Guru Member
    I recently used an Android 11 phone (Moto G8) with a ZLD 4.65P1 firmware without any issue...
  • Hello everybody,
    Thanks for your help.
    The problem is that ia have a Zywall 310. You think, it's compatible with L2TP VPN, Android11 and an Oppo Find X3 Pro  ?
    Best regards
  • mMontana
    IMVHO only Oppo could answer to that...
