L2TP over IPSEC no more working on Android 11(ColorOS 11.2)
Hello Everybody,
Since i change my smartphone, I can't connect on the L2TP over IPSEC vpn anymore.
My smartphone config:
- Android 11
- Smartphone Oppo Find X3 Pro (ColorOS 11.2)
The VPN Config : Like this guide searchArticle!viewBlob.action (zyxel.com)
The question is : Am i alone with this problem :-) ?
Thanks a lot for your help
- Android 11
Hi @virtuOS,L2TP VPN on our smartphone is able to be established to ATP200 (Firmware: 5.10(ABFW.0)).- Android 11- Xiaomi Mi A3We suggest you follow the wizard on the USG/ZyWALL/ATP/USG FLEX to configure L2TP VPN.0
I recently used an Android 11 phone (Moto G8) with a ZLD 4.65P1 firmware without any issue...0
Hello everybody,
Thanks for your help.
The problem is that ia have a Zywall 310. You think, it's compatible with L2TP VPN, Android11 and an Oppo Find X3 Pro ?
Best regards0 -
IMVHO only Oppo could answer to that...
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
