SSO restricts access to application through VPN tunnel
                    We have SSO working for all users, but we have a IPSEC VPN tunnel between Site A and Site B offices.
And when Web Authorization is enabled users at Site A cannot access application running on Site B.
This is a screen of our AuthPolicy.
Should i change Incoming to LAN and Destination to WAN to make it work?
thank you
thank you
            Best Answers
            Hi
 I think maybe It could use policy order to determine the auth poily hit .
            Where is the ad server placed? Is it in lan side of site A or site B? Do both site A and site B use the same ad server and the same SSO agent to do authentication?0
 I We have 2 ADs at both location, ADs are in trust relationship and connected using that VPN tunnel.jasailafan said:Where is the ad server placed? Is it in lan side of site A or site B? Do both site A and site B use the same ad server and the same SSO agent to do authentication?
 DO you think i should add second AD as authentication server as well?
            Hi
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 497 USG FLEX H Series
- 323 Security Ideas
- 83 Switch Ideas
- 49 Wireless Ideas
- 286 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
