Content filter ATP out of office
ticsystems
ticsystems Posts: 86 image  ZCNE Certified
First Answer First Comment Friend Collector Sixth Anniversary
Hi everyone. I would like to be able to apply content filtering outside of the office. I need a safe browsing of my clients. Is there a possibility with DNS filtering?
Thank's!!!!
«1
  • MJStar
    MJStar Posts: 37 image  Freshman Member
    First Answer First Comment Friend Collector Fourth Anniversary
    Thank's!!!!
    Can you describe more specifically about "to apply content filtering outside of the office"? Don't realize your use scenario very clearly.
  • ticsystems
    Thank's!!!!
    hello and sorry.
     I mean having the atp series content filter when I have an employee at home.
  • MJStar
    Thank's!!!!
    hello and sorry.
    Oh~~~so you would like to establish VPN connection(e.g L2TP , SSL VPN) from your home to company's ATP and whether ATP's DNS content filter can restrict this VPN access what kind of content just like you are in office ;) ?
  • ticsystems
    MJStar said:
    Thank's!!!!
    hello and sorry.
    Good Morning.
    What I want is to somehow apply dns filtering outside of office and vpn.
    Thanks!!!
  • WJS
    WJS Posts: 156 image  Master Member
    5 Answers First Comment Friend Collector Third Anniversary
    Hi ticsystems
    I can work dns filter via VPN user (L2tp over ipsec)
    client would got ip pool
    Let CNN,facebook response 1.1.1.1
    set two policy ( source : vpn pool , dst any(exclude zywall)  and zywall )
    #I used advance profile, But the meaning is the same
    anyway, just apply the dns filter
    successful
  • MJStar
    @ticsystems Just as @WJS mentioned that. You can add security policy with content filter profile to restrict the VPN IPs that can access what kind of internet content :3 .
  • ticsystems
    Thank you very much for your reply but I don't think you understand me.
    I know how to apply content filtering to IPsec clients. What I want is when they are not connected to the VPN.
    Thanks!
  • mMontana
    mMontana Posts: 1,461 image  Guru Member
    @ticsystems IMVHO... how the firewall could run that services... without the client connected to it?
  • ticsystems
    Already solved!!
    Thank's!
  • mMontana
    Would you please share the path for the solution? :-)
