Schedule disconnect of pppoe connection
Hello all!
One question: Here in Germany most DSL connections with dynamic IP are doing a dis- and reconnect from provider side every 24 hours.
To prevent that this happens during normal day-time several devices allow to schedule this on client side - this prevents an additional disconnect on provider side.
Is there a way to realize this in an USG-210 - so I can configure that like every day at 2am there is a disconnect and a re-connect of the PPPOE connection done?
Regards
Carsten
Regards
Carsten
Hi @CDS,
Here the steps,
1.Edit a CLI script text file with filename "disconnect_ppp.zysh" and have the following command.
interface disconnect wan1_ppp
Note: The ppp interface name is depends on your settings. In this example, the ppp interface is "wan1_ppp".
2.Go to GUI, MAINTENANCE > Filter Manager > Shell Script, select and upload the file.
3. Login to USG via SSH and type the following command.
Router# configure terminal
Router(config)# schedule-run 1 disconnect_ppp.zysh daily 02:00
Router(config)# write
Hi @CDS,
Here the steps,
After disconnect. When reconnect?zyman2008 said:Hi @CDS,
Here the steps,
Router(config)# write0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
