USG210: Use LAN-Clients on different WAN Ports
Hi everyone,
I ahd the idea to let the LAN Clienbts connect to different WAN Ports.
Our USG210 has two ISPs connected to WAN1 and WAN2, most used as failover or higher bandwidth.
Now we had the idea to set the USG, that some LAN Clients use only WAN1 and some should use only WAN2. Dont ask why, its a inhouse case...
I tried several declaration from the internet or this forum, f.e. with trunk, with zones, whatever should be possible, but i found no way.
The simplyest way coukd be over zones, but i cannot make two WAN Zones.
So is there anybody, who had the same question or idea, to do it so?
Thankyou!
IMVHO should be a case of Policy Routing...
Hello @Pasadena
As @mMontana says, it would seem to be down to policy based routing to direct different LAN traffic to different WAN ports.
Section 11.1 of the user guide https://download.zyxel.com/USG210/user_guide/USG210_V4.70_Ed1.pdf from https://www.zyxel.com/products_services/Unified-Security-Gateway-USG110-210-310/downloads talks about how to set this up.
The user guide says:
"use policy routes and static routes to override the Zyxel Device's default routing behaviour in order to send packets through the appropriate interface or VPN tunnel."
Kind regards,
Tony0
- 431 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 385 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
