Moving from USG50 to USG60?
I understand that the USG50 is obsolete with no further support. I looked at the recommended upgrade path and see I can upgrade up to the USG60. I have a couple of questions:
1. Will I be able to export my settings from the USG50 and import them into the USG60?
2. If I can do the import, will my settings be compatible with the USG60 such that I can use it without having to go through all the settings to check them?
3. Where can I find how much the software functions for the USG60 cost like content filtering, spam blocking etc
Thanks.
Hi @MTUSGUser,
Welcome to Zyxel community.
The answers to your question as following.
Yes, we have on-line converter, it can help to transfer USG50 configuration file to USG60.
https://www.zyxel.com/tw/zh/promotions/USG-Configuration-Converter-20130829-760081.shtml
It supposed to transfer all the settings from USG-50 to USG-60.
Not sure what is your region, here is region contact information, i would suggest to contact local support to get license info.
https://www.zyxel.com/where_to_buy/where-to-buy.shtml
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
