DHCP CSV IMPORT on USG flex 500 (V5.10(ABUJ.0))
Hello
The DHCP table has an import button to upload a csv file with IP addresses and the corresponding mac addresses to create dhcp reservations.
After fiddling around this for 2 hours.... I conclude it does not work??
IP address, mac address, description (less then 16 chars a-z,A-Z,0-9, - and _ )
Is there anyone able to use this feature? What is the magic trick?
Hi @JohnK,
Welcome to Zyxel community.
The format as below,IP Address,MAC Address,Description192.168.1.200,00:1E:33:28:4E:F5,testAttached file for your reference.0 -
ell, it wasn't me ;-) There is a bug, and it is reproducable by your techs. They are working on it...
The import feature seems to have a flaw...0 -
I trying to import static DHCP table (USG FELX 500 V5.36(ABUJ.1)). Fist of all, I try to import file from user Zyxel_Cooldia (see above). I get this message, but the entries not showing on te list:
Does the import function still seem to be broken?
Is there any workaround for this problem?
Posting my answer for all others, who will find this unsolved thread, after struggeling while trying to import a static DHCP list:
this solved my issue: see step 1.2 (you have to create at least one binding manually)
For all others, who will find this unsolved thread, after struggeling while trying to import a static DHCP list:
this solved my issue: see especially step 1.2 (you have to add at least one address firest)
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 6.3K Security
- 486 USG FLEX H Series
- 320 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 452 News and Release
- 4.3K FAQ
- 93 Security Highlight
