USG210: Use LAN-Clients on different WAN Ports
Pasadena
Pasadena Posts: 3 image  Freshman Member
Fourth Anniversary
edited November 2021 in Security
Hi everyone,
I ahd the idea to let the LAN Clienbts connect to different WAN Ports.
Our USG210 has two ISPs connected to WAN1 and WAN2, most used as failover or higher bandwidth.
Now we had the idea to set the USG, that some LAN Clients use only WAN1 and some should use only WAN2. Dont ask why, its a inhouse case...
I tried several declaration from the internet or this forum, f.e. with trunk, with zones, whatever should be possible, but i found no way.
The simplyest way coukd be over zones, but i cannot make two WAN Zones.
So is there anybody, who had the same question or idea, to do it so?
Thankyou!
