ZYWALL USG20 HTTP SERVER FAULT
HELLO TO ALL ... I HAVE A FIREWALL usg20 that they gave me, I reset it ... I access it with ssh and the login happens correctly ... when I access from the web server by typing 192.168.1.1 I am redirected to https: // 192.168.1.1/redirect.cgi?airp=192.168.1.1 getting the error "PR_CONNECT_RESET_ERROR" can anyone help me to solve ??
You can try to flush your browser cache first. If still doesn't help, you can use other PC to test it again.
If symptom still the same, you can try to click "reset" button over 5 seconds on USG20 panel to reset device again.
System start to reboot itself and apply system-default configuration. In the usual, all of USG services will works well.
- 431 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 385 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
