How to add hostnames to static dhcp reservations on USG Flex 500
Hi @JohnK
Title and post matched are a bit confusing.
The devices with "none" into the hostname... have static ip addresses configured into the device's TCP/IP Stack or are object of a reservation on DHCP server on your USGFlex 500?
If it's the second one, you can:- add a commend into the DHCP table for explaining what/who the macaddresses are
- add a DNS entry into the table at Configuration -> System -> DNS -> Address/PTR Record. Into this section not only a PTR/A record can be added, but moreover, CNAME and some other things.
well, it are dhcp reservations. So if I create PTR/A records, the will show their hostname instead of none in the dhcp table? I'll test that right away ;-)
Thanks0
- 3K Nebula
- 232 Nebula Ideas
- 6.7K Security
- 684 USG FLEX H Series
- 362 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 309 Service & License
- 504 News and Release
- 96 Security Advisories
- 5.1K FAQ
- 89 About Community
- 111 Security Highlight
