ZW USG20W-VPN don't disable policy routes on startup
Posts: 188  Master Member
edited November 2021 in Security
Hi all.
ZW USG20W-VPN with V5.10(ABAR.0) / 2021-09-23 22:23:04
3 vti interfaces (vti0, 1, 2) and 2 trunks vti with vti0,1 in active/active in WWR, vti_log with vti2 active WWR.
On vti enabled Connectivity Check.
2 Policy routes
1 to remote_lan2 via vti_log with enabled option "
Disable policy route automatically while Interface link down"
2 to any via vti.
In trunk vti_log status vti2 in dead state, but route don't disable automatically
Why device don't disable routes with inactive interfaces?
Update: a
s i understand, ZW don't disable dead policy routes on startup. Only that it founds during work.
Welcome!
It looks like you're new here. If you want to get involved, click on this button!
  • Posts: 188  Master Member
    Same thing on USG1100 with V4.70(AAPK.0). Routes with dead trunks don't disable.
    On
    V4.65(AAPK.0) all works fine.
    Update: other vti trunk with same settings was autodisabled.
    As i understand, ZW don't disable dead policy routes on startup.
  • Posts: 1,518  Zyxel Employee
    Hi @alexey
    Lab test based on your description. i can see the the policy route change to disable status.
    can you see alert log as below in Monitor > Log > View Log > Priority=alert ?
    Hi @Zyxel_Cooldia
    Logs are empty
    Log enables
    CC on vti enables
    Right after reboot i can see this events
    But vti1 sets in normal state after some time. vti0 & 2 in dead state
    @Zyxel_Cooldia
    Any help with this problem?
    Hi @alexey,
    We would like to conduct a lab test based on your configuration file. Can you send me your configuration file to me in private message.
    Hi @Zyxel_Cooldia
    I sent conf file.
    Same issue on other test site with same device on same fw.
    It don't disable routes via disconnected vti interface and via trunk with 2 disconnected vti after reboot.
    When i create them - routes disabled.
    After reboot them enabled and them don't disabled during work.
Welcome!
Welcome!
