DHCP CSV IMPORT on USG flex 500 (V5.10(ABUJ.0))
JohnK
JohnK Posts: 11
image  Freshman Member
edited November 2021 in Security
Hello
The DHCP table has an import button to upload a csv file with IP addresses and the corresponding mac addresses to create dhcp reservations.
After fiddling around this for 2 hours.... I conclude it does not work??
IP address, mac address, description (less then 16 chars a-z,A-Z,0-9, - and _ )
Is there anyone able to use this feature? What is the magic trick?
