mellanox 25G eth card on xs1930-10 by sfp28
Hi @xs1930,
Welcome to Zyxel Community!
From the port status image, we can see that port 9 is not even link up.
After investigating the network card and SFP you used, I notice that the Mellanox 4121A is able to perform 10G, but not for RTXM330-005. Seems that the SFP is only support 25G, so please ensure this SFP is backward compatibility to 10G.
In addition, you may consider Zyxel SFP which demonstrates in our switch datasheet.
For 10G, we have SFP 10G-SR and 10G-LR.
Hope it helps.Adam
Hi @xs1930,
Hope it helps.Adam
Thanks a lot ! I changed my cable with a 10G dac copper,then the eth card works . Now I konw the sfp28 cable could not auto-negotiation to sfp+, even the eth card and switcher can.0
- 243 Nebula Ideas
- 6.8K Security
- 784 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 58 Wireless Ideas
- 7.3K Consumer Product
- 325 Service & License
- 528 News and Release
- 102 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
