L2TP and SSL VPN
I have a question, can we use L2TP and SSL VPN simultaneously on a USG FLEX 100?
I configured SSL VPN, and it works perfectly, but I'm unable to use L2TP, even on the log not showing connecting attempt I made.
Would you please tell me whether it is possible to use these VPNs simultaneously on one device?
Thank you
Thank you
Yes its possible0
Hi @srihiru,The IP address pool for SSL VPN and L2TP VPN cannot be in the same subnet. Besides, the IP address pool for SSL VPN and L2TP VPN cannot conflict with any other existing wan/lan/dmz/wlan even if they are not in use.0
- 601 USG FLEX H Series
- 480 News and Release
