USG 40 throughput
Hi @cpanagopWhat firmware version you are running now?Do you encounter the same symptom as the original post since this fix should be included in the current release. Would you share the symptom on your device more detail?If you are still running firmware prior to 4.60, you may upgrade it to V4.62 and to see if everything going well.Thanks.0
I am also experiencing similar issues. Upgraded internet speed to 400mbps, and I can only get about 150mbps going through USG40 (firmware v4.65).
The USG40 is a light weight when it comes to speed on a single core its rated speed is done with Maximum throughput based on RFC 2544 (1,518-byte UDP packets) TCP will be much less.
first try going to monitoe > system status > traffic statistics > uncheck collect statistics
As a test go to config > system > advanced and enable
Going by the site it looks like USG 40/60 is being EOL how long the firmware will be updated for them models is unknown. site updated now showing them....Seems it displays them for https://www.zyxel.com/products_services/security-firewall.shtml?t=c but not for https://www.zyxel.com/uk/en/products_services/security-firewall.shtml?t=c
Thanks for the suggestions. Disabling "Collect Statistics" brought the speed up to 270mbps, and enabling "Fast Forwarding" further increased the speed to 390mbps.For future reference, how can I find out specification like this? Which line item on the product spec page reflect this? I have been considering upgrading to Flex 100, and now I am wondering what speed I can expect out of it.Once again, thanks for the help.0 -
Did you compared specs between USG40 and USG Flex 100? As chassis and port budget they seem comparable, but IMVHO intersting questions are:jfoxwu said:I have been considering upgrading to Flex 100, and now I am wondering what speed I can expect out of it.
will you upgrade your connection bandwidth into next 3 years?
to what cap?
This might be a in important gamechanger for a budget conscious choice.0 -
If you want 1Gb by TCP you need to go like USG FLEX 500 or VPN3000
What is the expected throughput for a USG40 with app features on (virus, IDP,..)?I had 100Mbs service and measured on avg 104Mbps. Upgrades to 300Mbs and getting avg 111Mbs0
Hi @tesagigHere is a test result from our lab, it could give you a reference, as below:Topology:Internet <-> ( WAN) USG40( LAN) <-> PCCondition:1. The UL/DL of the WAN interface is 1000Mbps2.USG40 enables UTM features3.PC is behind NAT4.PC execute speedtest(http)The test result of PC:The download throughput is 127.8 Mbps, the upload throughput is 100.32 Mbps.0
thanks for sharing this. So, I am limited with the USG40 to a 100Mbps subscription +/-. What device would allow 300Mps?
Hi @tesagigBased on the same test criteria: The USG Flex 100 download throughput is 582 Mbps, and upload throughput is 571.8Mbps. It could give you a reference. Thanks.0
- 588 USG FLEX H Series
- 477 News and Release
