zywall usg 20 how to change from adsl to fibre
Hi @Eugenekg,
Do you know the new ISP fiber type is static IP or PPPoE?
If the new ISP is static IP, go to “Configuration > Network > Interface > Ethernet”, to set up static IP address provided from service provider.If it is same as before, just go to “Configuration > Object > ISP account”, edit ISP profile for new ISP ID and password.5
Hi @Eugenekg,
If the new ISP is static IP, go to “Configuration > Network > Interface > Ethernet”, to set up static IP address provided from service provider.If it is same as before, just go to “Configuration > Object > ISP account”, edit ISP profile for new ISP ID and password.5 -
Thank you very much.0
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
