Need some clarification on Zyxel security products
Hi @gga,
Welcome to Zyxel community.
Yes, we have other products without that cloud stuff, I think USG series might meet your requirement.
Here is the specifications for your reference.
https://www.zyxel.com/products_services/Unified-Security-Gateway-USG40-40W-60-60W/comparison#specifications
For minimizing administrative efforts at multiple-site or large-scale deployments, we also have software based management tool which can install on local site(not cloud based).
It can centralized control, easy management over your network
https://www.zyxel.com/tw/zh/products_services/Security-Management-Appliance-Cloud-CNM-SecuManager/application
thx.Somebody mentioned, the USG áre pretty old and will be replaced by new, modern types like the cloud managed devices - can you comment that?Another questions: the usg come with licenses for Anti-(virus, spam,...). Is that license user based and how and at what cost can it be prolongued?0
Hi @gga
1. Somebody mentioned, the USG áre pretty old and will be replaced by new, modern types like the cloud managed devices - can you comment that?
Currently the total cloud management solution device is Nebula series. You can reference to following weblink:https://www.zyxel.com/products_services/Cloud-Managed-Security-Gateways-Nebula-Cloud-Managed-Security-Gateways/specification
If Nebula product is not your requirement, you can reference to standalone models like USG or ZyWALL VPN series.
USG series: https://www.zyxel.com/products_services/Unified-Security-Gateway-USG40-40W-60-60W/quick-finder
VPN series: https://www.zyxel.com/products_services/VPN-Firewall-ZyWALL-VPN50-100-300/quick-finder
And SecuManager is a software installed on local PC.It can remote managing USG and ZyWALL VPN series.
2. Another questions: the usg come with licenses for Anti-(virus, spam,...). Is that license user based and how and at what cost can it be prolongued?
You can purchase the license by click “Buy” link. On the WebGUI.
It will redirect to web site, and you can purchase licenses you need directly.
I still need some info comparing NSG and USG:what I read is that the USG(W) comes witha. Firewall plusb. AVc. SPAMd. WLANNSG is a. only - is that right?So why should I use NSG if I have only one site to administrate?thx.0
The NSG supports Content Filtering, Anti-Virus, APP Patrol, and Firewall functions.
The Nebula server is not only used for managing the NSG, but also NSW series and NAP series.
NAP:
NSW:
Nebula is a cloud based total solution which is able to manage the Gateway, Switch and AP.
- 431 Beta Program
- 2.6K Nebula
- 164 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
