New owner of an GS1900-24 - Naming the ports
3liasen
3liasen Posts: 1 image  Freshman Member
edited July 2024 in Switch Ideas
UPDATE: RTFM! :-)   Found out how to do the naming part, but can it be shown in the main STATUS window when hovering the ports?
Finally got to the point in my life, where I got me a switch which can hold all my connections. Previously I've used a Dymo to print a label for each cable. Is it possible to give the ports names in the configuration, e.g. port 24 = Philips Hue Bridge, port 15 = Printer etc. and - most important - see it in the STATUS windows GUI?
Thanks in advance,
Jan
3 votes
Active · Last Updated
  • Zyxel_Jason
    Zyxel_Jason Posts: 429 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula Zyxel Certified Sales Associate
    edited April 2021
    Hi @3liasen ,
    Thanks for your input.
    I will transfer this thread to Idea section and monitor new comments and votes afterwards for evaluating reference.
    Jason
  • Fragments
    Fragments Posts: 1 image  Freshman Member
    I would also like to Opt-In on this idea. Having visible port names(on mouse hover) on the Virtual Device view would make the interface a lot more compelling. And as there is no new information to be saved it should be a really small change.
  • mMontana
    mMontana Posts: 1,461 image  Guru Member
    Opt-in myself to. A 32 char label (alphanumerical, some special chars like - and , or . might be really useful. HPE don't provide the feature on all devices, unfortunately.
  • e_mano_e
    e_mano_e Posts: 116 image  Ally Member
    First Answer First Comment Friend Collector Sixth Anniversary
    It would also be helpful if the port names were shown everywhere where ports are configured.
    E.g. "Configuration - Port - EEE" and "Configuration - Port - PoE" and "Configuration - QoS - General"
