Unexpected reboot then increased loopback traffic
Hi @SMarkG,
How frequent does it happen? Can you send me diag-infor via private message for analyzing.
Maybe we can see something abnormal in the diag-info.
Diag-inforcollection:
1) Go to “MAINTENANCE > Diagnostics > Collect”, Click “Collect now”.
It may take 5~10 minutes to collect system information.
2) After it done, go to “Files” tab to download diag-info.
Hi @Zyxel_Cooldia, thanks for getting back to me.This has never happened before and the 310 has previously been very stable but for some reason last week it just rebooted without warning and then we saw the increased loopback traffic.I have generated the diagnostic file as advised (which does show a "Fatal Error Cause System Reboot" at the correct date/time, so hopefully there's enough information in there for you to be able to identify the cause. I will send it to you shortly.Thank you very much for your help.
Hi @SMarkG,
The issue is fixed on V4.70. Please update to V4.70 and monitor if it still have crash issue.0 -
Hi @Zyxel_Cooldia
Thanks for the reply. I updated to v4.70 after the incident first happened so hopefully the problem won't repeat.
Thanks for your help.0
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 365 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 263 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
