Pool size issue
I'm struggling with an USG310 firewall.
I have an interface which IP is 192.168.0.1, netmask 255.255.252.0.
I'd like to setup its DHCP server so as the pool starts at 192.168.1.1 and ends at 192.168.3.229 (pool size 737).
The problem is that the firewall does not allow me to specify a pool larger than 250.
If I change the inicial address to 192.168.0.1, then I'm allowed to specify a size of 500 (aprox).
I don't understand the reason. Any help? Thanks in advance!
Hi @carles
Welcome to Zyxel community.
Before you saving the IP address and DHCP configuration, the system checking if it has overlap to others interfaces.
In the default setting, your interface address 192.168.0.0/22 has overlap to LAN2 and dmz interfaces. So you can’t save configuration successfully.
5
Sorry,
I didn't take attention to the settings of the other interfaces...0 -
Hi @carles
5
- 431 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 385 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
