NAT not working on my ATP200
HCWang
HCWang Posts: 2 image  Freshman Member
First Anniversary
this is my topology.
ATP200 has firmware 5.10(ABFW.0) , FLEX 200 has firmware 5.10(ABUI.0)
i have setup SSL vpn on flex200 with port 4430
on ATP200, i have configured NAT TCP port 4430 to forward to my flex 200, it did not work. I tried to plug my pc to ATP200 LAN interface and ssl vpn to flex200, it works.
Using SSL vpn by connecting from Internet does not work.
here is the NAT setup i did on my atp 200
because NAT is not working, i have disabled policy control under security policy on both devices.
Can you help on this issue please?
Thank you
    PeterUK Posts: 4,437 image  Guru Member
    edited December 2021 Answer ✓
    Odd I have a setup that does the same thing and works but with other ports/IPs and zywall 110 to USG40.
    Have you used External IP for NAT is interface type for WAN1 IP instead of IP?
    Can you run a packet capture of the atp 200 for WAN1 and port scan 4430 to be sure its hitting the WAN1
    GRC | Port Authority, for Internet Port 4430
  • HCWang
    First Anniversary
    Hello Peter
    thanks for the support. i changed my port for the SSL vpn from 4430 to 446, i am able to dial-in via SSL vpn now.
    Thank you
    Johnson
