Nat Loopback not Working
I have an ATP700 behind DMZ and Nat LoopBack is not working.
Thanks!
Your ISP router would have to do NAT Loopback of your WAN IP.
The way NAT Loopback works is say your LAN PC has 192.168.1.2 and you want to go to your WAN IP to loopback to server PC 192.168.1.3 with your NAT rule with loopback to a port.
As your WAN IP is not the WAN IP NAT loopback can't loopback because your WANIP is 172.26.10.245 which is not the WAN IP your going too.
How can it work if you don't give your WAN interface the WAN IP
If you put in 172.26.10.245 then it will loop back to the port on the LAN
have you done a from LAN to LAN rule?
Hello Peter.
I don't have create a lan to lan rule.My ISP Redirect all ports to 172.26.10.245 (ge2 Atp700)If I add the object with my public IP in "External IP" the ports are not open.If I add the object "interface IP" (172.26.10.245)in "internal ip" the ports are open but nat loopback does not work.If I delete any object in "Internal ip" and add any. The ports are open.What do I have to add so that my firewall knows what my Public IP is and works?0 -
I am not used to working behind DMZ. I usually work with Public IP on my ATP WAN.
A feature you could put in ideas is to add other IP/FQDN to NAT loopback for.
PeterUK dijo:Su enrutador ISP tendría que hacer NAT Loopback de su IP WAN.
La forma en que funciona NAT Loopback es decir que su PC LAN tiene 192.168.1.2 y desea ir a su IP WAN para hacer un loopback a la PC servidor 192.168.1.3 con su regla NAT con loopback a un puerto.
Como su IP de WAN no es la IP de WAN, el bucle de retorno de NAT no puede realizar un bucle de retorno porque su WANIP es 172.26.10.245, que no es la IP de WAN a la que va también.
I don't understand. An FQDN with my WAN ip 172.26.10.245?
something like this:
something like this:This option does not appear in ATP. Is there any way for it to appear?0 -
Its a mock-up of whats needed you have to put it in ideas
Another way that should work is by DNS in the ATP to have your domain point to the internal IP of the server.
Doing a test you might be able to get NAT loopback work if your WAN IP is static all you have to do is make another NAT rule with the same setting and put in your real External WAN IP even if it not on the ATP interface.
- 435 Beta Program
- 176 Nebula Ideas
- 426 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
