Nat Loopback not Working
ticsystems
ticsystems Posts: 86  ZCNE Certified
First Answer First Comment Friend Collector Nebula Gratitude
Hello!
I have an ATP700 behind DMZ and Nat LoopBack is not working.
If my public ip is set to External it doesn't work.
I have added security policy.
Thanks!
    PeterUK Posts: 4,020  Guru Member
    Your ISP router would have to do NAT Loopback of your WAN IP.
    The way NAT Loopback works is say your LAN PC has 192.168.1.2 and you want to go to your WAN IP to loopback to server PC 192.168.1.3 with your NAT rule with loopback to a port.
    As your WAN IP is not the WAN IP NAT loopback can't loopback because your WANIP is 172.26.10.245 which is not the WAN IP your going too.
«1
    edited December 2021
    How can it work if you don't give your WAN interface the WAN IP
    If you put in 172.26.10.245 then it will loop back to the port on the LAN
    have you done a from LAN to LAN rule?
  • ticsystems
    Hello Peter.
    I don't have create a lan to lan rule.
    My ISP Redirect all ports to 172.26.10.245 (ge2 Atp700)
    If I add the object with my public IP in "External IP" the ports are not open.
    If I add the object "interface IP" (172.26.10.245)
    in "internal ip" the ports are open but nat loopback does not work.
    If I delete any object in "Internal ip" and add any. The ports are open.
    What do I have to add so that my firewall knows what my Public IP is and works?
  • ticsystems
    Thank's Pete
    I am not used to working behind DMZ. I usually work with Public IP on my ATP WAN.
    A feature you could put in ideas is to add other IP/FQDN to NAT loopback for.
  • ticsystems
    PeterUK dijo:
    Su enrutador ISP tendría que hacer NAT Loopback de su IP WAN.
    La forma en que funciona NAT Loopback es decir que su PC LAN tiene 192.168.1.2 y desea ir a su IP WAN para hacer un loopback a la PC servidor 192.168.1.3 con su regla NAT con loopback a un puerto.
    Como su IP de WAN no es la IP de WAN, el bucle de retorno de NAT no puede realizar un bucle de retorno porque su WANIP es 172.26.10.245, que no es la IP de WAN a la que va también.
    PeterUK dijo:
    I don't understand. An FQDN with my WAN ip 172.26.10.245?
    But 172.26.10.245 is not your true WAN IP so if your WAN IP is 5.2.2.2 you put that in NAT loopback even if the WAN IP is 172.26.10.245 it will loopback for 5.2.2.2 your true WAN IP
    something like this:
  • ticsystems
    Hy Peter. Happy new year!
    This option does not appear in ATP. Is there any way for it to appear?
    Its a mock-up of whats needed you have to put it in ideas
    Another way that should work is by DNS in the ATP to have your domain point to the internal IP of the server.
    edited January 2022
    Doing a test you might be able to get NAT loopback work if your WAN IP is static all you have to do is make another NAT rule with the same setting and put in your real External WAN IP even if it not on the ATP interface.
