How do I set up guest SSID
I am having trouble getting my head round running a second wifi SSID for guest usage, one that will be on a separate subnet. Currently LAN1 is configured for the local subnet on P4, and this connects to an unmanaged switch for the main network and wifi access points for staff.
The access points are configured via a single web interface and I have created a new SSID and associated it with a VLAN ID. On the USG110, I have created a new vlan, with the same VLAN ID as above, with DHCP enabled, and set to a separate subnet.
At this point I am stuck. The new SSID is visible but I cannot get it to work.
However, I may well have got things wrong. Could anyone explain the basic steps that I should have taken, including what connects to what?
I appreciate any suggestions.
Thank you. It will take me a while to work through it but this looks just what I was after.
Dear @AfterDark
If i am right and this is your topology
It's really not so complicated..
i hope this is clear to you
after that setup an ssid with the corresponding vlan
And that should do the trick
NOTE.
Really important is that you have a policy control rule for the vlan to talk to the zywall, otherwise clients will not get an ip adress.
And normally you settup a second rule where you say Vlanx to Wan allow
But maybe the unmanged switch can be your bottleneck here..
I hope it's passes the vlan's without dropping packages0 -
I follow the manual but when I enable the workers wifi and the guest wifi both stop to work.
The SSID appear and desappear constantly.
Hi @SergioM
Which firmware version is working on your device?
Can you send me your configuration by private message?
- 603 USG FLEX H Series
- 481 News and Release
