Nat Loopback not Working
2»
  • ticsystems
    ticsystems Posts: 84  ZCNE Certified
    First Answer First Comment Friend Collector Nebula Gratitude
    edited January 2022
    PeterUK said:
    Doing a test you might be able to get NAT loopback work if your WAN IP is static all you have to do is make another NAT rule with the same setting and put in your real External WAN IP even if it not on the ATP interface.
    I have tested it and it does not work. When putting the private ip it does not open ports.
    This is how to configure it from the beginning.
    PeterUK Posts: 3,891  Guru Member
    You make one rule with private ip 172.26.10.245 for External IP you then make another rule for the same port with External IP being your real WAN IP. So that for LAN you go to your domain which will be your WAN IP and the ATP should loopback
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,537  Zyxel Employee
    Hi @ticsystems,
    You can try to add an internal DNS A record (e.g. www.xxx.com 172.26.10.245) in ATP700, and LAN side hosts DNS server set to ATP-700. Once LAN hosts access to www.xxx.com, it will not go ISP router.
  • ticsystems
    Hi @ticsystems,
    I have a active directory server. I will look at configuring it on the Windows DNS server. Thanks!!!
  • ticsystems
    EIt is not the ideal solution but it work.
    Thanks!
  • ticsystems
    Hi all. It is not a viable option. Behind the domain xxx.com they have a lot of external services and it should generate a lot of A records. I need natloopback to work.
    The way I said will work you need a LAN to LAN firewall rule for it to work.
