How to make a link between a UAG50 and a NWA1123-AC ?
Hi @Uneeti
NWA1123-AC is a standalone AP. Could you share with us what your scenario is? You want NWA1123-AC to get IP address from UAG50 and let NWA1123-AC provide WiFi service in your environment? Or Do you have other usage for NWA1123-AC?
Thanks.
Joslyn0 -
Hi @Zyxel_Joslyn, Sorry for the late response, I want to extend the uag50 wifi network with two terminals NWA1123-AC but I do not know if this is possible. I can not configure the NWA1123-AC in slave mode of the UAG50, it would be necessary that users can pass from one terminal to another without interruption. The NWA1123-AC must distribute the same Wi-Fi network as the UAG50. I do not know if I'm clear, thank you.
Hi @Uneeti
If the SSID and authentication method are the same on the UAG50 and NWA1123-AC, the client can do roaming between these devices. Because the station will keep the SSID and login information. While the station connects to the new AP, it will connect to the same SSID automatically and send the login information to the AP.
Thanks.
Joslyn0
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
