[Bug USG210] After upgrade lost of modified DCHP settings
FrankLauer
FrankLauer Posts: 50  Ally Member
First Comment First Answer Friend Collector Fourth Anniversary
edited December 2021 in Security
- In FW slot 1 I have V4.65(AAPI.1).
- I made there different DHCP modifications like setting DHCP from server to relay, deleting static addresses and add some IPv6 DHCP stuff.
- In FW slot 2 I uploaded V4.70(AAPI.0) and rebooted.
- After reboot I have lost these modifications and it seems that I got all DHCP settings from the previous configuration in FW slot 2.
I also checked both config files from slot 1 and slot 2 with a diff tool. And indeed the only differences was these DHCP settings.
I have expected that settings are taken over from one slot to another while upgrading.
Best Answers
  • FrankLauer
    Just wanted to note what I had discussed with support by mail:
    The USG is syncing the conf files exactly at the point when you upload a firmware to a slot. If you don't restart the new firmware in the new slot immediately you will lost the changes between upload and restart.
    In my case I have done the restart some days later. That's the reason for the lost.
    Hope this will help somebody with the same problem and thanks for the support.
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,538  Zyxel Employee
    Hi @FrankLauer,
    Device would not sync configuration all the time, it only sync at the first time when you update firmware.
    e.g.  the running partition is slot 1, and we update firmware on slot 2 without reboot.
    After firmware update process, it only bring the configuration from slot 1 to slot 2 during firmware update process, which means if you modify any settings in slot 1 after firmware update. it would not sync to slot 2. That's why you can see the difference.
  • warwickt
    warwickt Posts: 111  Ally Member
    5 Answers First Comment Friend Collector Third Anniversary
    Hello FrankLauer , it's unusual that the current settings would have been purged from the xxx.config file .
    :s I will say in the past that ofcourse that we have certainly 'lost' current setting from one firmware switch to another using your technique above. :'(
    However the settings are usually there on one of the config files.   B)
    You might start with looking at the existing conf files you have on you the usg210 appliance by logging into the router (ssh) and doing this:
    dir /conf/
    In this example usg110 below, there's a bunch from way way back.. all ok ..
    ( :s Sadly the 'code' formatting in this zyxel web site is dreadful (bloody awful!).. so here is the text as best as I might put it in a block.. but is wont format  :'( )
    Router> dir /conf/
    File Name        Size     Modified Time
    system-default.conf        72473    2021-12-08 06:11:05
    startup-config.conf        164214   2021-12-12 20:34:15
    lastgood.conf        166424   2021-12-08 06:15:04
    autobackup-0.00.conf        105067   2017-05-09 16:13:30
    lab-usg110-01_2020-08-01.conf        150887   2020-08-01 15:34:14
    lab-usg110-01_2020-09-13.conf        153917   2020-09-13 09:11:26
    lab-usg110-01_2017_may_26.conf        104473   2017-05-26 17:56:06
    lab-usg110-01_2017_may_11_V4.25.conf        104430   2017-05-11 13:44:47
    lab-usg110-01_2017_may_29.conf        104652   2017-05-29 17:37:07
    lab-usg110-01-2017_julu_31.conf        106212   2017-07-31 13:23:35
    lab-usg110-01_2017_aug_01.conf        105931   2017-07-31 18:40:41
    lab-usg110-01_2017_aug_03.conf        104950   2017-08-03 21:36:57
    autobackup-4.32.conf        123123   2019-04-13 18:19:33
    lab-usg110-01_2019_may_08.conf        125932   2019-05-08 15:49:50
    lab-usg110-01_2019-may-16.conf        126183   2019-05-16 10:56:30
    lab-usg110-01_2019_Jun_13.conf        126456   2019-06-14 18:04:32
    lab-usg110-01_2019_june_15.conf        128699   2019-06-15 14:24:33
    lab-usg110-01_2019-June-24.conf        129155   2019-06-24 15:21:05
    lab-usg110-01_2019-july-04.conf        134029   2019-07-04 00:11:19
    lab-usg110-01_2019-july_05_ospf.conf        135317   2019-07-05 19:41:06
    lab-usg110-01_2019_july-30.conf        136955   2019-07-30 12:55:47
    lab-usg110-01_2019-oct-01.conf        138756   2019-10-01 14:25:42
    lab-usg110-01_2020-03-26.conf        144745   2020-03-26 19:37:08
    lab-usg110-01_2020-04-02.conf        146596   2020-04-02 21:57:08
    lab-usg110-01_2020-04-23.conf        146861   2020-04-23 19:08:36
    435AAKY3-2020-04-25-05-16-34.conf        146861   2020-04-25 05:16:34
    lab-usg110-01_2020-05-12.conf        147384   2020-05-12 13:54:47
    435AAKY3-2020-08-14-05-11-28.conf        151004   2020-08-14 05:11:28
    lab-usg110-01_2020-09-20.conf        156037   2020-09-20 12:14:45
    439AAKY0-2020-12-31-13-17-09.conf        158278   2020-12-31 13:17:09
    autobackup-4.39.conf        158278   2020-12-31 14:13:28
    lab-usg110-01.2020-12-31_no_overide_policy_routes.conf        159893   2020-12-31 16:21:59
    460AAKY1-2021-01-26-05-28-52.conf        162716   2021-01-26 05:28:52
    lab-usg110-01_2021-03-11.conf        163652   2021-03-11 12:20:53
    autobackup-4.62.conf        164722   2021-07-14 13:55:14
    465AAKY0-2021-08-26-05-21-12.conf        165209   2021-08-26 05:21:12
    465AAKY0-2021-11-09-05-10-53.conf        165198   2021-11-09 05:10:53
    lab-usg110-01_2021-11-27.conf        165193   2021-11-27 07:34:54
    autobackup-4.70.conf        166432   2021-12-08 06:13:01
    lab-usg110-01_2019-dec-19.conf        141095   2019-12-19 17:47:07
    autobackup-4.35.conf        145662   2020-03-08 11:48:37
    lab-usg110-01_2020-03-20.conf        145724   2020-03-20 17:09:59
    Router>
    You may prowl around and upload a couple of the last conf files you have.
    Our practice:
    is to always
    1.  save a new conf file prior to upgrading any formware.. (hindsight is  wonderful human characteristic ofcourse  :#
    2. copy that .conf file to an external host as a contingency
    You could look for these file names, copy them, rename them and uplaod them and restart on your previous firmware to make sure that those settings are there.
    These files might look like:
    • system-default.conf
    • startup-config.conf
    • lastgood.conf
    • autobackup-0.00.conf
    • 465AAKY0-2021-11-31-05-10-53.conf <--- this is auto made from V4.65 flavour firmware)
    or even one suffixed with a recent firmware name  data....  try them all and you will find that these settings may be there... see #5 above ..
    HTH
    Warwick
    Hong Kong
  • Zyxel_Cooldia
    Please send me your configuration file in PM. We would like to test firmware update from V4.65 to V4.70 based on your configuration file.
  • FrankLauer
    Thank you both for answering.
    As far I see the problem as follows: On Dec 12th I upgraded the firmware. Before I made a custom backup of the last config file of FW 4.65 to my local disk. This is the header of the file:
    ! saved at 2021-12-12 02:03:06
    ! model: USG210
    ! firmware version: 4.65(AAPI.1)
    After upgrade in slot 2 to 4.70 the first file is: autobackup-4.65.conf. But in the header of this autogenerated file you can see a much older date. And this is the reason why I got an old configuration set.
    (Last change: 2021-12-12 11:00:25  size 112291)
    ! saved at 2021-12-07 15:49:34
    ! model: USG210
    After saving the configuration in slot 2 for the first time to a custom file I got an identical file like the autogenerated file but with the new header of FW 4.70
    (Last change: 2021-12-12 11:04:53  size 112291)
    ! saved at 2021-12-12 11:04:43
    ! model: USG210
    ! firmware version: 4.70(AAPI.0)
    So I lost the modifications I made between 7th of Dec. and 12th of Dec. (But could restore manually.)
    Zyxel_Cooldia I will send you the 3 conf files by PM (without any additional comments). Thank you.
  • FrankLauer
  • Zyxel_Cooldia
    Hi @FrankLauer,
