[Bug USG210] After upgrade lost of modified DCHP settings
FrankLauer
- In FW slot 1 I have V4.65(AAPI.1).
- I made there different DHCP modifications like setting DHCP from server to relay, deleting static addresses and add some IPv6 DHCP stuff.
- In FW slot 2 I uploaded V4.70(AAPI.0) and rebooted.
- After reboot I have lost these modifications and it seems that I got all DHCP settings from the previous configuration in FW slot 2.
I also checked both config files from slot 1 and slot 2 with a diff tool. And indeed the only differences was these DHCP settings.
I have expected that settings are taken over from one slot to another while upgrading.
Best Answers
Just wanted to note what I had discussed with support by mail:The USG is syncing the conf files exactly at the point when you upload a firmware to a slot. If you don't restart the new firmware in the new slot immediately you will lost the changes between upload and restart.In my case I have done the restart some days later. That's the reason for the lost.Hope this will help somebody with the same problem and thanks for the support.0
Hi @FrankLauer,
Device would not sync configuration all the time, it only sync at the first time when you update firmware.
e.g. the running partition is slot 1, and we update firmware on slot 2 without reboot.
After firmware update process, it only bring the configuration from slot 1 to slot 2 during firmware update process, which means if you modify any settings in slot 1 after firmware update. it would not sync to slot 2. That's why you can see the difference.
Hello FrankLauer , it's unusual that the current settings would have been purged from the xxx.config file .
I will say in the past that ofcourse that we have certainly 'lost' current setting from one firmware switch to another using your technique above.
However the settings are usually there on one of the config files.
You might start with looking at the existing conf files you have on you the usg210 appliance by logging into the router (ssh) and doing this:
dir /conf/
In this example usg110 below, there's a bunch from way way back.. all ok ..
(Sadly the 'code' formatting in this zyxel web site is dreadful (bloody awful!).. so here is the text as best as I might put it in a block.. but is wont format
==========================================================Router> dir /conf/File Name Size Modified Timesystem-default.conf 72473 2021-12-08 06:11:05startup-config.conf 164214 2021-12-12 20:34:15lastgood.conf 166424 2021-12-08 06:15:04autobackup-0.00.conf 105067 2017-05-09 16:13:30lab-usg110-01_2020-08-01.conf 150887 2020-08-01 15:34:14lab-usg110-01_2020-09-13.conf 153917 2020-09-13 09:11:26lab-usg110-01_2017_may_26.conf 104473 2017-05-26 17:56:06lab-usg110-01_2017_may_11_V4.25.conf 104430 2017-05-11 13:44:47lab-usg110-01_2017_may_29.conf 104652 2017-05-29 17:37:07lab-usg110-01-2017_julu_31.conf 106212 2017-07-31 13:23:35lab-usg110-01_2017_aug_01.conf 105931 2017-07-31 18:40:41lab-usg110-01_2017_aug_03.conf 104950 2017-08-03 21:36:57autobackup-4.32.conf 123123 2019-04-13 18:19:33lab-usg110-01_2019_may_08.conf 125932 2019-05-08 15:49:50lab-usg110-01_2019-may-16.conf 126183 2019-05-16 10:56:30lab-usg110-01_2019_Jun_13.conf 126456 2019-06-14 18:04:32lab-usg110-01_2019_june_15.conf 128699 2019-06-15 14:24:33lab-usg110-01_2019-June-24.conf 129155 2019-06-24 15:21:05lab-usg110-01_2019-july-04.conf 134029 2019-07-04 00:11:19lab-usg110-01_2019-july_05_ospf.conf 135317 2019-07-05 19:41:06lab-usg110-01_2019_july-30.conf 136955 2019-07-30 12:55:47lab-usg110-01_2019-oct-01.conf 138756 2019-10-01 14:25:42lab-usg110-01_2020-03-26.conf 144745 2020-03-26 19:37:08lab-usg110-01_2020-04-02.conf 146596 2020-04-02 21:57:08lab-usg110-01_2020-04-23.conf 146861 2020-04-23 19:08:36435AAKY3-2020-04-25-05-16-34.conf 146861 2020-04-25 05:16:34lab-usg110-01_2020-05-12.conf 147384 2020-05-12 13:54:47435AAKY3-2020-08-14-05-11-28.conf 151004 2020-08-14 05:11:28lab-usg110-01_2020-09-20.conf 156037 2020-09-20 12:14:45439AAKY0-2020-12-31-13-17-09.conf 158278 2020-12-31 13:17:09autobackup-4.39.conf 158278 2020-12-31 14:13:28lab-usg110-01.2020-12-31_no_overide_policy_routes.conf 159893 2020-12-31 16:21:59460AAKY1-2021-01-26-05-28-52.conf 162716 2021-01-26 05:28:52lab-usg110-01_2021-03-11.conf 163652 2021-03-11 12:20:53autobackup-4.62.conf 164722 2021-07-14 13:55:14465AAKY0-2021-08-26-05-21-12.conf 165209 2021-08-26 05:21:12465AAKY0-2021-11-09-05-10-53.conf 165198 2021-11-09 05:10:53lab-usg110-01_2021-11-27.conf 165193 2021-11-27 07:34:54autobackup-4.70.conf 166432 2021-12-08 06:13:01lab-usg110-01_2019-dec-19.conf 141095 2019-12-19 17:47:07autobackup-4.35.conf 145662 2020-03-08 11:48:37lab-usg110-01_2020-03-20.conf 145724 2020-03-20 17:09:59Router>
You may prowl around and upload a couple of the last conf files you have.
Our practice:
is to always- save a new conf file prior to upgrading any formware.. (hindsight is wonderful human characteristic ofcourse
- copy that .conf file to an external host as a contingency
You could look for these file names, copy them, rename them and uplaod them and restart on your previous firmware to make sure that those settings are there.
These files might look like:- system-default.conf
- startup-config.conf
- lastgood.conf
- autobackup-0.00.conf
- 465AAKY0-2021-11-31-05-10-53.conf <--- this is auto made from V4.65 flavour firmware)
or even one suffixed with a recent firmware name data.... try them all and you will find that these settings may be there... see #5 above ..
HTH
Warwick
Hong Kong
1 - save a new conf file prior to upgrading any formware.. (hindsight is wonderful human characteristic ofcourse
Hi @Franklauer,Please send me your configuration file in PM. We would like to test firmware update from V4.65 to V4.70 based on your configuration file.0
Thank you both for answering.As far I see the problem as follows: On Dec 12th I upgraded the firmware. Before I made a custom backup of the last config file of FW 4.65 to my local disk. This is the header of the file:! saved at 2021-12-12 02:03:06
! model: USG210
! firmware version: 4.65(AAPI.1)After upgrade in slot 2 to 4.70 the first file is: autobackup-4.65.conf. But in the header of this autogenerated file you can see a much older date. And this is the reason why I got an old configuration set.(Last change: 2021-12-12 11:00:25 size 112291)! saved at 2021-12-07 15:49:34
! model: USG210
! firmware version: 4.65(AAPI.1)After saving the configuration in slot 2 for the first time to a custom file I got an identical file like the autogenerated file but with the new header of FW 4.70(Last change: 2021-12-12 11:04:53 size 112291)! saved at 2021-12-12 11:04:43
! model: USG210
! firmware version: 4.70(AAPI.0)So I lost the modifications I made between 7th of Dec. and 12th of Dec. (But could restore manually.)Zyxel_Cooldia I will send you the 3 conf files by PM (without any additional comments). Thank you.
Hi @FrankLauer,
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
